ShiftX3
- ShiftX3
- 2 #6 screws for surface mounting
- ShiftX3
- RJ45 CAN hub
- Low profile RJ45 Cable
Dimensions
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
Non OBDII installation
- Note:
RJ45 power cable for ShiftX3
ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
Red | +12v | Brown |
White | Ground | Orange/White |
No Connection | CAN 1 High | Orange |
No Connection | CAN 1 Low | Green/White |
Black | CAN 2 High | Blue |
Yellow | CAN 2 Low | Blue/White |
CAN Base Address
The default CAN base address is 935424 (0xE4600). You can change it by breaking the trace bridging the ADR1 jumper on the bottom of the ShiftX3 circuit board.
Closed (Default setting) | 935424 (0xE4600) |
Open | 935680 (0xE4700) |
CAN Baud Rate
Closed (Default setting) | 500K |
Open | 1MB |
Scripts
Disco Lights Demo
Script
setTickRate(30) -- Set configuration. Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, bright,sxAutoBrightScaling,orientInverted) function rndc() return math.random(0,255) end function onTick() for i=0,9,1 do r = rndc() g = rndc() b = rndc() sxSetLed(i,1,r,g,b,0) end sxSetDisplay(0, math.random(0,9)) end
Sequential shift light
Script
setTickRate(30) -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM function onTick() sxUpdateLinearGraph(getChannel("RPM")) end
Assumptions:
Script
setTickRate(30) -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM --configure first alert (right LED) as engine temperature (F) sxSetAlertThresh(0,0,205,255,255,0,0) --yellow warning at 205F sxSetAlertThresh(0,1,225,255,0,0,10) -- red flash at 225F --configure second alert (left LED) as oil pressure (PSI) sxSetAlertThresh(1,0,0,0,0,255,10) --red flash below 15 psi sxSetAlertThresh(1,1,15,255,255,0,5) --yellow flash 15-20 PSI sxSetAlertThresh(1,2,20,0,0,0,0) --above 20, no alert function onTick() --update RPM sxUpdateLinearGraph(getChannel("RPM")) --update engine temp alert sxUpdateAlert(0, getChannel("EngineTemp")) --update oil pressure alert sxUpdateAlert(1, getChannel("OilPress")) end
Script
-- Predictive time visualizer --save best lap time bestTime = 0 -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(1,0,0,200) --center-out graph, linear style, +/- 10.0 seconds in 0.1 sec resolution sxSetLinearThresh(0,0,0,255,0,0,0) --red if you're falling behind best lap sxSetLinearThresh(1,0,80,0,0,255,0) --blue if you're close to best lap sxSetLinearThresh(2,0,110,0,255,0,0) --green if you're beating best lap setTickRate(30) function onTick() local predTime = getPredTime() local timeDiff = (bestTime - predTime) * 60 -- rail values timeDiff = math.max(timeDiff, -10) timeDiff = math.min(timeDiff, 10) --scale values from +/- 10 sec to a 0-200 scale timeDiff = (timeDiff + 10) * 10 sxUpdateLinearGraph(timeDiff) --update best lap time if an updated lap time is available local lastLapTime = getLapTime() if lastLapTime < bestTime or bestTime == 0 then bestTime = lastLapTime end end
Boost Gauge
Assumptions
Script
setTickRate(30) -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(0,0,0, 20) --left to right graph, linear style, 0 - 20 PSI boost sxSetLinearThresh(0,0,0,0,255,0,0) --green starting at no boost sxSetLinearThresh(1,0,10,255,255,0,0) --yellow starting at 10 PSI boost sxSetLinearThresh(2,0,15,255,0,0,10) --red+flash at 15 PSI boost function onTick() local map = getChannel("MAP") --convert to PSI boost local boost = math.max(map - 100, 0) * .145038 sxUpdateLinearGraph(boost) end
ShiftX3 CAN bus API
Offset | What | Value |
1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
2 | Red | 0 - 255 |
3 | Green | 0 - 255 |
4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
1 | Red | 0 - 255 |
2 | Green | 0 - 255 |
3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
1 | Threshold ID | 0 - 4 |
2 | Threshold (low byte) | |
3 | Threshold (high byte) | |
4 | Red | 0 - 255 |
5 | Green | 0 - 255 |
6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
1 | Value (low byte) | |
2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
2 | Low Range (low byte) | |
3 | Low Range (high byte) | |
Set Linear Graph Threshold
CAN ID: Base + 41
0 | Threshold ID | 0 - 4 |
4 | Red | 0 - 255 |
CAN ID: Base + 42
0 | Value (low byte) | |
1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
