Add TPMS Data
You can cheaply and easily add Tire Pressure Monitor System data to your Race Capture Pro or Podium Connect devices with the $225 TrailBrake.com CAN enabled TPMS. The system is available in external screw on sensors and internal rim mounted sensors.
Both are available for $225. Both have channels for pressure, temperature, volts (to monitor battery life), and leak alarm.
For the Race Capture Pro MK3, you can wire CAN High and CAN Low to either CAN 1 or CAN 2. CAN 1 is recommended as that is what the provided Preset defaults to. If you wire it to CAN bus 2, you will have to go into each TPMS channel and change it from CAN Bus 1 to CAN Bus 2.
For Podium Connect, you can add wires to CAN Bus 2 on the Molex connector. Again, after applying the Preset, you will have to go in and change the CAN Bus 1 to CAN Bus 2 for each TPMS channel.
You can also create a custom RJ45 cable and put the TPMS on either CAN 1 or CAN2. Please see this [RacecapturePro_MK3_hardware_install#RJ45_CAN_.2B_Power_connection link for more info]. This would also allow the TPMS system to work with older Race Capture Pro MK2 systems.
The external sensors use inexpensive CR1632 watch batteries. They only last a few days of endurance racing, so you will want to monitor the volts and probably change batteries before each race weekend. The internal sensors last about 3 years so not as important to monitor volts on those.
