Add TPMS Data
Revision as of 19:14, 25 March 2019 by Sbarton (talk | contribs)
You can cheaply and easily add Tire Pressure Monitor System data to your Race Capture Pro or Podium Connect devices with the $225 TrailBrake.com CAN enabled TPMS.
The system is available in external screw on sensors and internal rim mounted sensors.
Both are available for $225. Both have channels for pressure, temperature, volts (to monitor battery life), and leak alarm.
For the Race Capture Pro MK3, you can wire CAN High and CAN Low to either CAN 1 or CAN 2. CAN 1 is recommended as that is what the provided Preset defaults to. If you wire it to CAN bus 2, you will have to go into each TPMS channel and change it from CAN Bus 1 to CAN Bus 2. RaceCapturePro MK3 Rear Diagram.png RaceCapture Pro MK3 Molex CAN pinout.png
For Podium Connect, you can add wires to CAN Bus 2 on the Molex connector. Again, after applying the Preset, you will have to go in and change the CAN Bus 1 to CAN Bus 2 for each TPMS channel. PodiumConnect SIM card.jpg RC CANBus.jpg
You can also create a custom RJ45 cable and put the TPMS on either CAN 1 or CAN2. Please see this link for more info. This would also allow the TPMS system to work with older Race Capture Pro MK2 systems.
Now that you have the system hooked up, go into the Race Capture App, turn on and make sure the baud rate is set to 1M for the CAN Channel you wired the TPMS to.
Now go to CAN Mapping, click on Presets. click Update at bottom, then Select TrailBrake.com TPMS
Write the changes to your device and you should now be able to see your TPMS data in Race Capture dashboard. [[Image:RC_TPMS_Data1.jpg]|500px]]
