MJLJ V4 vehicle installation guide
Parts you will need
- EDIS-8 for 8 cylinder
- EDIS-6 for 6 cylinder
- EDIS-4 for 4 cylinder
EDIS installation
Type | Degrees BTDC |
EDIS-4 | 90 |
EDIS-6 | 60 |
EDIS-8 | 50 |
Megajolt Lite Jr. Wiring
- Use 16 gauge wire for the MJLJ ground connection. 18-20 gauge wiring is fine for signal connections.
- If the MJLJ is fitted with the internal hard rev limiter, it's recommended you use at least 16 gauge wire for +12v power and the Coil Power output, and connect it to a fused circuit with suitable current capacity. Otherwise you may use 18-20 gauge wire for the power connection.
- For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Using EDIS PIP signal
Smiths RVI type tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
