MJLJ V4 vehicle installation guide
Revision as of 23:20, 29 May 2008 by Brentp (talk | contribs) (Using EDIS PIP signal: removed this section, because in theory, the 12V output on the MJLJ should drive these tachometers.)
Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Megajolt Lite Jr. Wiring
  • For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
