MJLJ V4 vehicle installation guide
Parts you will need
- EDIS-8 for 8 cylinder
- EDIS-6 for 6 cylinder
- EDIS-4 for 4 cylinder
EDIS installation
Type | Degrees BTDC |
EDIS-4 | 90 |
EDIS-6 | 60 |
EDIS-8 | 50 |
Megajolt Lite Jr. Wiring
- Use 16 gauge wire for the MJLJ ground connection. 18-20 gauge wiring is fine for signal connections.
- If the MJLJ is fitted with the internal hard rev limiter, it's recommended you use at least 16 gauge wire for +12v power and the Coil Power output, and connect it to a fused circuit with suitable current capacity. Otherwise you may use 18-20 gauge wire for the power connection.
- For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Many tachometers can accept the signal emitted from the Tach Out on the MJLJ module. This Tach Out signal provides a 12V pulse for every ignition event. You may use this to provide the signal to compatible tachometers, or to provide a signal to a separate Engine Control Unit, data logger, or other device which requires athis signal.
Smiths RVI type tachometers
Enabling Option Switch
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
