RCP stimulator
Connect the stimulator to the RaceCapture/Pro inputs using the following diagram.
- You can provide power + ground to RCP using the 12v and Ground outputs on the Stimulator. The power and ground on the RCP will not provide power or ground to the Stimulator. The Stimulator needs its own power.
- The power plug is a 5.5x2.5mm. A 5.5x2.1 may also work.
- You can use a 5V USB adapter to power it, however it may not have enough power to also power the RCP. If using 5V USB to power the Stimulator, you will also need to plug the RCP into USB to power the RCP seperately.
- Here is a cheap 5V USB power adapter that will work with the Stimulator. https://amzn.to/2XwSF1w
- RCP MK3 plug is a standard 24 pin Molex ATX computer power plug. You can buy an ATX extension cable for $7. Cut the cables in half and wire the male end to the Stimulator terminal blocks. You could then use the female end to make an adapter to go from RCP MK3 molex to RCP MK2 20 pin terminal block. This would allow you to use your Stimulator for both MK3 and MK2 RCP's.
- Do not connect the stimulator's 5v output to the 5v VREF output on RaceCapture/Pro; it is only provided for reference.
- The AUX TX/ RX line needs to be connected in the following fashion so data can flow correctly:
- Stimulator AUX_TX -> RCP AUX_RX
- Stimulator AUX_RX -> RCP AUX_TX
- CAN bus 1 and 2 are bridged together; you can disable this by breaking the PCB jumpers on the bottom side of the board, near terminal block, using a razor knife or a very small screwdriver
- You can download a preset config file for the Stimulator here: File:RCP Stimulator MK3.zip
- The blue 5 pin female and 6 pin male headers are for programming the microcontroller. The button between them is for putting the microcontroller into bootloader mode. Do not use these unless instructed to.
Analog outputs
RPM/Pulse outputs
4 Pulse outputs are provided to stimulate up to 4 RPM/Pulse inputs. The pulse outputs work well for simulating a low (420) to high (10,000) RPM range using the following RPM channel settings:
- 1 pulse per revolution
- Medium Speed timer channel
- RPM mode
GPIO
Input Mode
Output mode and Demo script
- Note Ensure the GPIO ports are in output mode under RaceCapture Setup / Digital In/Out.
--Demo script for toggling LEDs on stimulator board --GPIOs must be set for output mode in RaceCapture Setup setTickRate(1) count = 0 function onTick() --toggle LEDs local state = count % 2 setGpio(0, state == 0) setGpio(1, state == 0) setGpio(2, state == 0) count = count + 1 end
CAN bus output
4 knobs control the value of 4 CAN channels. These channels are broadcast on CAN ID 276. The baud rate is 500k:
- Channel 1: Offset 0, length 2
- Channel 2: Offset 2, length 2
- Channel 3: Offset 4, length 2
- Channel 4: Offset 6, length 2
The CAN data is broadcast as a raw value between 0-10000 and can be scaled further using the CAN channel mapping.
Note:
Baud Rate
Baud rate is 115200, 8N1
Format
- Timestamp in milliseconds
- Channel 1 value (0-10000)
- Channel 2 value (0-10000)
- Channel 3 value (0-10000)
- Channel 4 value (0-10000)
- Value echoed back from received data
--initialize Aux serial port to 115200, 8, N, 1 initSer(6, 115200, 8, 0, 1) setTickRate(10) function onTick() --write something to be echoed back writeSer(6, 'echo') --read a line from the aux serial port with a 100ms timeout value = readSer(6, 1000) if value ~= nil and value ~= '' then print('read value: ' ..value) end end
352023 ,0,0,0,0,echo 352223 ,0,0,0,0,echo 352423 ,0,0,0,0,echo 352623 ,0,0,0,0,echo 352823 ,0,0,0,0,echo 353023 ,0,0,0,0,echo 353223 ,275,0,0,0,echo 353423 ,1680,0,0,0,echo 353623 ,1680,0,0,0,echo 353823 ,1680,0,0,0,echo 354023 ,1672,0,0,0,echo 354223 ,1697,1181,0,0,echo 354423 ,1699,2666,0,0,echo 354623 ,1704,2649,0,0,echo 354823 ,1706,2656,0,0,echo 355023 ,1692,2647,0,0,echo 355223 ,1728,4554,0,0,echo 355423 ,1724,4595,0,0,echo 355623 ,1741,4588,0,0,echo 355823 ,1753,4590,1199,0,echo 356023 ,1750,4588,1323,0,echo 356223 ,1755,4588,4730,0,echo 356423 ,1750,4588,4984,0,echo 356623 ,1758,4586,4981,0,echo 356823 ,1750,4583,4959,1299,echo 357023 ,1758,4586,4964,4129,echo 357223 ,1758,4588,4947,4473,echo 357423 ,1753,4586,4957,5269,echo 357623 ,1753,4586,4957,5768,echo
