MJLJ V4 vehicle installation guide
Revision as of 01:19, 30 May 2008 by Brentp (talk | contribs) (added links to troubleshooting, operation guide)
Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Megajolt Lite Jr. Wiring
  • For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Many tachometers can accept the signal emitted from the Tach Out on the MJLJ module. This Tach Out signal provides a 12V pulse for every ignition event. You may use this to provide the signal to compatible tachometers, or to provide a signal to a separate Engine Control Unit, data logger, or other device which requires athis signal.
Smiths RVI type tachometers
The controller firmware applies Hysteresis to the user outputs. For RPM, the hysteresis threshold is 100 RPMs; for Load and Auxiliary input, the threshold is 1 KPa/1% TPS for Load, and 1 Auxiliary Input unit for Auxiliary input triggered outputs.
Enabling Option Switch
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
If the advance does not change, or appears jittery or unstable, see the Troubleshooting Section for additional help.
