MJLJ V4 vehicle installation guide
Parts you will need
- EDIS-8 for 8 cylinder
- EDIS-6 for 6 cylinder
- EDIS-4 for 4 cylinder
Type | Donor Vehicle | Years | Market |
EDIS-4 | Ford Escort | 1990-99 | US |
Ford Fiesta | 1990-93 | Europe | |
Ford Escort | 1990-93 | Europe | |
Ford Sierra | 1990-93 | Europe | |
Ford Mondeo | 1990-93 | Europe | |
EDIS-6 | Ford Ranger Pickup truck | 1990-97 | US |
Mazda B-Series Pickup | 1990-97 | US | |
Ford Explorer | 1990-97 | US | |
Mazda Navajo | 1990-97 | US | |
Ford Aerostar | 1990-97 | US | |
Ford Scorpio 2.9 Cosworth | 1996-97(?) | Europe
EDIS-8 | Crown Victoria | 1990-97 | US |
Mercury Grand Marquis | 1990-97 | US | |
Lincoln Town Car | 1990-97 | US | |
Ford Thunderbird | 1990-97 | US | |
Mercury Cougar | 1990-97 | US | |
Ford Mustang 5.0 | 1990-97 | US |
- Coil packs: Many use the matching Ford coil packs, but typically most OEM coil packs that reasonably closely match the ford EDIS primary and secondary DC coil resistance should work fine.
- Trigger wheel: Many adapt the trigger wheel removed from the crank pulley of a donor engine- others machine the pattern into an existing wheel, or purchase a ready-made wheel.
For those of you in the UK, a supplier of trigger wheels and EDIS parts can be found here: www.trigger-wheels.com t
EDIS installation
Type | Degrees BTDC |
EDIS-4 | 90 |
EDIS-6 | 60 |
EDIS-8 | 50 |
Megajolt Lite Jr. Wiring
- Use 16 gauge wire for the MJLJ ground connection. 18-20 gauge wiring is fine for signal connections.
- If the MJLJ is fitted with the internal hard rev limiter, it's recommended you use at least 16 gauge wire for +12v power and the Coil Power output, and connect it to a fused circuit with suitable current capacity. Otherwise you may use 18-20 gauge wire for the power connection.
- For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Many tachometers can accept the signal emitted from the Tach Out on the MJLJ module. This Tach Out signal provides a 12V pulse for every ignition event. You may use this to provide the signal to compatible tachometers, or to provide a signal to a separate Engine Control Unit, data logger, or other device which requires athis signal.
Smiths RVI type tachometers
The controller firmware applies Hysteresis to the user outputs. For RPM, the hysteresis threshold is 100 RPMs; for Load and Auxiliary input, the threshold is 1 KPa/1% TPS for Load, and 1 Auxiliary Input unit for Auxiliary input triggered outputs.
Enabling Option Switch
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
If the advance does not change, or appears jittery or unstable, see the Troubleshooting Section for additional help.
