GPIO Output
Revision as of 02:36, 28 July 2019 by Sbarton (talk | contribs)
GPIO Output to control switches, relays, LEDs, etc
Relays
If you have a device you want to control that requires more than 1A, you will need to use a Relay to power it. Normally a SPST relay would have a constant 12v, constant Ground, 12v Output, and input 12v that triggers the relay and sends 12v to the Output. To control a standard 4 pin SPST Relay with RCP, You would have constant 12v, but instead of switched 12v input, that will now also always be hot, and instead of constant ground, you will have switched ground controlled by the RCP.
LEDs
Most small LED indicator lights can be controlled directly with RCP. Wire power directly to the LED, and wire the ground to the GPIO of the Race Capture Pro. Triggering the GPIO of the RCP will ground the LED turning it on.
Lua Scripting for GPIO's
In order to turn on a GPIO you need to do so with in the Lua script. Once turned on(ie. setGpio(1,1) , it will stay on until you explicitly turn it off (ie. setGpio(1,0)
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2
  • returns:
    • none
