MJLJ V4 vehicle installation guide
Revision as of 02:02, 30 May 2008 by Brentp (talk | contribs) (updated EDIS parts section)
Parts you will need
  • EDIS module: Acquire an EDIS Ignition module matching your engine type- EDIS-4 for 4 cylinder engines; EDIS-8 for 8 cylinders; EDIS-6 for 6 cylinders
EDIS Donor vehicles
EDIS-4 Ford Escort 1990-99 US
Ford Fiesta 1990-93 Europe
Ford Escort 1990-93 Europe
Ford Sierra 1990-93 Europe
Ford Mondeo 1990-93 Europe
Ford Explorer 1990-97 US
Mazda Navajo 1990-97 US
Ford Aerostar 1990-97 US
Lincoln Town Car 1990-97 US
Ford Thunderbird 1990-97 US
Mercury Cougar 1990-97 US
Ford Mustang 5.0 1990-97 US
For those of you in the UK, a supplier of trigger wheels and EDIS parts can be found here: www.trigger-wheels.com t
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Megajolt Lite Jr. Wiring
  • For MAP based setups ignore the TPS connection.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Many tachometers can accept the signal emitted from the Tach Out on the MJLJ module. This Tach Out signal provides a 12V pulse for every ignition event. You may use this to provide the signal to compatible tachometers, or to provide a signal to a separate Engine Control Unit, data logger, or other device which requires athis signal.
Smiths RVI type tachometers
The controller firmware applies Hysteresis to the user outputs. For RPM, the hysteresis threshold is 100 RPMs; for Load and Auxiliary input, the threshold is 1 KPa/1% TPS for Load, and 1 Auxiliary Input unit for Auxiliary input triggered outputs.
Enabling Option Switch
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
If the advance does not change, or appears jittery or unstable, see the Troubleshooting Section for additional help.
