Raspberry Pi Tips
- Choose the fastest MicroSD card you can for fastest boot times. 32gb is plenty big and reasonably cheap. Class 10 is preferred. I used this one:
- On a computer, format the card to FAT32 format
- Download the latest Raspberry Pi Image to the computer
Start Pi and Update OS
- Place the MicroSD card in the Pi, connect a LAN cable to the Pi's Cat5 connection for internet access, and power up.
- Login: pi
- Password: raspberry
sudo apt-get clean
sudo raspi-config
- Choose Desktop/CLI as Pi
- Highlight #4 Localisation Options and hit enter. I live in the Eastern Timezone of the US - customize this to your location.
- Choose I1 Change Locale
- Hit enter
sudo nano /boot/cmdline.txt
- Inside this file, make the following changes:
- Append the following to the end of the line:
sudo nano /boot/config.txt
disable_splash=1
Change keyboard to US
cd /opt
sudo tar -xjvf race...
Setup for Mausberry circuit
sudo nano /etc/rc.local
- Reboot to take effect.
sudo reboot
Set up for DFRobot display
- http://wiki.dfrobot.com/7_HDMI_Display_with_Capacitive_Touchscreen_SKU__DFR0506
- Uncomment this line:
disable_overscan=1
- Add this line:
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_group=2 hdmi_mode=87
- Change kivy settings:
General Notes and Commands
Run Racecapture manually
Make cursor visible
cursor = 1
Exit RaceCapture
Manually shutdown pi
Sudo Shutdown -h now
Rotate screen 180*
- Add this line:
display_rotate=2
- Modify this line:
