AnalogX
In the kit you will receive:
- AnalogX module
- 4 wire power and CAN pigtail
- 6 wire analog sensor input pigtail
- 1" shrink tube for installation
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
The Autosport Labs Linear Fluid Temperature sensor has a 10mV/C scaling, with a 0.5V offset at 0C.
150 PSI pressure sensor
Therefore, 150 PSI / 4000mV = 0.0375 PSI/mV
Other sensors
No CAN data
- Verify the CAN baud rate is compatible with the AnalogX configuration (500K by default, 1MB with jumper modified)
- Verify your CAN bus termination is correct. AnalogX is terminated by default.
Basic mapping test
| Feature | Description |
| Analog input voltage range | 0 - 5v |
| Pullup resistor | Optional on-board 2.2K pullup resistor for each channel (jumper enabled) |
| Harness | 26 gauge leads for power, ground, CAN and sensor inputs |
| Weight | 6 grams |
| Dimensions | 0.72" x 1.93" (18.3mm x 48.7mm) |
| CAN baud rate | 500K and 1M, jumper configurable |
| Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (jumper configurable) |
Source Code
Power and CAN
Pin 1 is on left when facing board connector
| Pin | Assignment | Notes |
| 1 | 9-15v Power | Connect this to switched ignition power. 0.25A max consumption. |
| 2 | CAN High | |
| 3 | CAN Low | |
| 4 | Ground |
Sensor connections
Pin 1 is on left when facing connector
| 1 | Analog 1 input | 0-5v input |
| 2 | Analog 2 input | 0-5v input |
| 3 | Analog 3 input | 0-5v input |
| 4 | Analog 4 input | 0-5v input |
| 5 | Voltage reference output (for powering sensors) | 5v @ 0.5A |
| 6 | Ground reference |
CAN termination
AnalogX CAN bus API
Adjusting Base ID
Address
| Offset | What | Value |
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Configuration Group 1
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
| 5 | Reserved | |
| 6 | Reserved | |
| 7 | Reserved |
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
| 0 | Channel 1, low byte | |
| 2 | Channel 2, low byte | |
| 4 | Channel 3, low byte | |
| 6 | Channel 4, low byte | |
| 7 | Channel 4, high byte |
