Megasquirt CAN
Megasquirt Integration
Channels enabled:
- Engine RPM (RPM)
- Throttle Position (TPS)
- Air/Fuel Ratio (AFR)
- And more
Megasquirt Wiring
RaceCapture/Apex
Use the CAN High and Low connections from either CAN1 or CAN2. Typically CAN1 is used, so you would use CAN 1 High' and CAN 1 Low.
RaceCapture/Pro MK3
Use the CAN High and Low connections from either CAN1 or CAN2 on the 24 pin Molex harness. Typically CAN1 is used, so you would use CAN 1 High' and CAN 1 Low.
RaceCapture/Pro MK2 and MK3 RJ45
You can use a standard CAT-5 ethernet cable with RJ45 connectors to integrate with RaceCapture/Pro MK2 and MK3
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
- Note: If you have RaceCapture/Pro powered through the terminal block and grounded at the same location, all you need to wire are the two CAN ligh/CAN low connections. You do not need to separately connect ground and power via the RJ45 port.
Microsquirt
Megasquirt 2 V3
- CAN High - DB37 Pin 3 (SPR1)
- CAN Low - DB37 Pin 4 (SPR2)
MS3 Pro
- CAN High: Pin 34
- CAN Low : Pin 33
Photos
Enable Megasquirt CAN broadcast
In TunerStudio, enable CAN mode and burn it to the controller. Once this is done, RaceCapture/Pro will be receiving CAN bus data from the Megasquirt.
Megasquirt Preset
Verifying
Once connected and with the preset loaded, navigate to the Dashboard screen in the RaceCapture app to verify data connectivity.
