TireX
Feature | Description |
Sensor Type | Thermal Array |
Temperature Range | -40 - 200C |
Accuracy | 1C |
Temperature Zones | 1 / 2 / 4 / 8 / 16 |
Sample Rate | 0.5 - 64Hz |
Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
Temperature Compensation | Automatic |
Electrical | |
Supply Voltage | 6 - 12v |
Power | 200mW |
CAN bus | |
CAN baud rate | 500K and 1M, jumper configurable (500K default) |
Address Space | 4 separate address spaces (jumper configurable) |
Termination | No Termination (jumper configurable) |
Physical / Environmental | |
Weight | 10 grams |
Operating temperature | -40 to 85C |
IP Rating | IP65 |
