TireX
Revision as of 01:49, 19 March 2020 by Brentp (talk | contribs)
High Performance
Rugged and Compact
Flexible Setup
Orientation can be inverted for consistent data reporting between left and right sides of vehicle. Temperature zones, preferences, and calibration are customizable by the end user. CAN bus can be set for 500 or 1MB.
Feature Description
Sensor type Thermal array
Object temperature range -40 - 200C
Field of view 120 degrees
Accuracy 1C
Temperature zones 1 / 2 / 4 / 8 / 16
Sample rate 0.5 - 64Hz
Processing Engine 32 bit
Temperature compensation Automatic
Electrical
Interface CAN 2.0
Supply voltage 6 - 12v
Power 200mW
Address space 4 separate address spaces (jumper configurable)
Termination No Termination (jumper configurable)
Physical / Environmental
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
Operating temperature -40 to 85C
IP rating IP65
CAN bus protocol
