TireX
High Performance
Rugged and Compact
Flexible Setup
Orientation can be inverted for consistent data reporting between left and right sides of vehicle. Temperature zones, preferences, and calibration are customizable by the end user. CAN bus can be set for 500 or 1MB.
Feature | Description |
Sensor type | Thermal array |
Object temperature range | -40 - 200C |
Field of view | 120 degrees |
Accuracy | 1C |
Temperature zones | 1 / 2 / 4 / 8 / 16 |
Sample rate | 0.5 - 64Hz |
Processing Engine | 32 bit |
Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
Temperature compensation | Automatic |
Electrical | |
Interface | CAN 2.0 |
Supply voltage | 6 - 12v |
Power | 200mW |
CAN bus | |
CAN baud rate | 500K and 1M, jumper configurable (500K default) |
Address space | 4 separate address spaces (jumper configurable) |
Termination | No Termination (jumper configurable) |
Physical / Environmental | |
Weight | 10 grams |
Operating temperature | -40 to 85C |
IP rating | IP65 |
CAN bus protocol
CAN base ID is 0xA100 (41216)
Adjusting Base ID
- Opening the jumper ADR1 will add 4096 to the base ID
- Opening the jumper ADR2 will add 8192 to the base ID.
Sensor Position Offset
The sensor position will offset the base ID by the position of the sensor as defined in the table:
ID | Location | Offset |
0 | Left-Front | 0x0 (0) |
2 | Left-Rear | 0x200 (512) |
0 | Right-Rear | 0x300 (768) |
Sensor Position | Final Sensor Base Address |
Left-Front | 0xA100 |
Right-Front | 0xA200 |
Left-Rear | 0xA300 |
Right-Rear | 0xA400 |
