TireX
High Performance
Rugged and Compact
Flexible Setup
- Orientation can be inverted for consistent data reporting between left and right sides of vehicle by assigning a position to the sensor
- CAN bus can be set for 500 or 1MB (default is 500K)
Feature | Description |
Sensor type | Thermal array |
Object temperature range | 0 - 127.5C |
Field of view | 120 degrees |
Accuracy | 1C |
Temperature zones | 1 / 2 / 4 / 8 / 16 |
Sample rate | 0.5 - 64Hz |
Processing Engine | 32 bit |
Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
Temperature compensation | Automatic |
Electrical | |
Interface | CAN 2.0 |
Supply voltage | 6 - 12v |
Power | 200mW |
CAN bus | |
CAN baud rate | 500K and 1M, jumper configurable (500K default) |
Address space | 4 separate address spaces (jumper configurable) |
Termination | No Termination (jumper configurable) |
Physical / Environmental | |
Weight | 10 grams |
Operating temperature | -40 to 85C |
IP rating | IP65 |
CAN bus protocol
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value | Symbol Reference |
8 Bit values | A |
A configured TireX sensor will have a CAN base address that is a combination of the Main Base ID + Position Offset based on the installed position of the sensor on the vehicle. This combination creates a final Sensor Base ID
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
The sensor position will offset the Main Base ID by the position of the sensor as defined in the table, to set the final Sensor Base ID
0 | Left-Front | 0x0 (0) |
2 | Left-Rear | 0x200 (512) |
Left-Front | 0xA100 |
Right-Front | 0xA200 |
Left-Rear | 0xA300 |
Right-Rear | 0xA400 |
Address
CAN ID: Sensor Base ID + 0
0 | Sample Rate | unsigned | A * 1 | Sample Rate (Hz) |
1 | Temperature Zones | unsigned | A * 1 | Number of configured temperature zones (1 / 2 / 4 / 8 / 16) |
3 | Reserved | |||
4 | Reserved | |||
Address
CAN ID: Sensor Base ID + 2
0 | Current Sample Rate | unsigned | A * 1 | 0.5 - 64Hz (0 = 0.5Hz) |
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
Configuration Preferences
Address
CAN ID: Sensor Base ID + 3
0 | Sample Rate | unsigned | A * 1 | Rate to report sensor values ( 0.5 - 64Hz). Valid sample rates: 0 (0.5Hz) / 1 (1Hz) / 2 (2Hz) / 4 (4Hz) / 8 (8Hz) / 16 (16Hz) / 32 (32Hz) / 64 (64Hz). Specifying an invalid value will select the default value of 16 |
2 | Sensor Position | unsigned | A * 1 | Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear). Specifying an invalid value will select the default value of 0 (Left-Front). Note: The sensor position affects the orientation of the sensor zones. Sensor Position 1 and 3 will report temperature zones left - right; Position 0 and 2 will report temperature zones right - left. |
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Calibration Preferences
Address
CAN ID: Sensor Base ID + 4
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Sensor Value Broadcast
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
