RaceCapture on Raspberry Pi
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
Display
Enclosure
Installed on Dashboard
Power Supply
To power everything, you'll need a high quality 5v power supply with 2 amps minimum capacity; 3 amps is highly recommended. You'll preferably want one designed to be hard wired into your car for maximum reliability.
Heat sinking
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
Powering up
- Launch the RaceCapture app by running:
Connection and usage
Extra Features
Hardwire buttons
- N : to indicate 'No"
Additional Tips
