AnalogX2
(AnalogX2 image)
In the kit you will receive:
  • AnalogX2 module
Cabling is available separately.
Harness / Cabling
Plug and play harness
AnalogX is designed for plug and play connection into Autosport Labs CAN bus networks and sensors. Refer to the part numbers below to create your own sensor configuration.
SKU Description
ASL_M8_SENSOR_EXTENSION_1M
ASL_M8_SENSOR_EXTENSION_2M
ASL_M8_SENSOR_EXTENSION_3M
ASL_M8_SENSOR_EXTENSION_4M
Bare pigtails
Refer to the table for bare pigtails:
SKU Description
Compatible Sensors
Setting CAN baud rate
(set baud rate image)
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
  • 0.5v 0 bar / = 0 PSI
  • 4.5v = 10 bar / 150 PSI
Therefore,
  • Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
  • 0.5v = 0 bar / 0 PSI
  • 4.5v = 150 bar / 2175 PSI
Other sensors
No CAN data
Basic mapping test
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Harness 26 gauge leads for power, ground, CAN and sensor inputs
Weight 6 grams
Source Code
Power and CAN
Pin 1 is on left when facing board connector
Pin Assignment Notes
1 9-15v Power Connect this to switched ignition power. 0.25A max consumption.
2 CAN High
3 CAN Low
4 Ground
Sensor connections
1 Analog 4 input 0-5v input
2 Analog 3 input 0-5v input
3 Analog 2 input 0-5v input
4 Analog 1 input 0-5v input
5 Voltage reference output (for powering sensors) 5v @ 0.5A
6 Ground reference
CAN termination
  • Note: Use a razor or very fine tipped screwdriver to break the bridge on the pad, scraping towards the outside of the circuit board. To re-enable the bridge, solder across the pads using a low wattage (15-30W) soldering iron to prevent damage to the pads.
AnalogX CAN bus API
Adjusting Base ID
Closed Open 0xE4700 (935680)
Open Closed 0xE4800 (935936)
Open Open 0xE4900 (936192)
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
