AnalogX2
In the kit you will receive:
- AnalogX2 module
Harness / Cabling
Plug and play harness
AnalogX is designed for plug and play connection into Autosport Labs CAN bus networks and sensors. Refer to the part numbers below to create your own sensor configuration.
| SKU | Description |
| ASL_4X_SENSOR_SPLITTER | 4X sensor expander |
| ASL_M8_SENSOR_EXTENSION_1M ASL_M8_SENSOR_EXTENSION_2M ASL_M8_SENSOR_EXTENSION_3M ASL_M8_SENSOR_EXTENSION_4M |
| ASL_LINEAR_TEMP_M8 | Linear temperature sensor |
| ASL_10_BAR_DELPHI3_M8 | 10 bar (150 PSI) pressure sensor |
| ASL_150_BAR_DELPHI3_M8 | 150 bar (2175 PSI) pressure sensor |
| ASL_M8_SENSOR_PIGTAIL_2M | Single sensor pigtail for custom sensor connection, 2 Meters |
Bare pigtails
For a custom or non-plug and play installiion, these bare pigtail cables are available:
| SKU | Description |
| ASL_DEVICE_CAN_PIGTAIL_1M | CAN + power pigtail for connecting device, M8 4P male to bare wires, 1 meter |
| ASL_M8_QUAD_SENSOR_PIGTAIL_2M | M8 8P male to bare wire quad sensor pigtail, 1M, 24AWG |
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
- 0.5v 0 bar / = 0 PSI
- 4.5v = 10 bar / 150 PSI
Therefore,
- Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
- 0.5v = 0 bar / 0 PSI
- 4.5v = 150 bar / 2175 PSI
Other sensors
No CAN data
Basic mapping test
| Feature | Description |
| Analog input voltage range | 0 - 5v |
| Pullup resistor | Optional on-board 2.2K pullup resistor for each channel (jumper enabled) |
| Harness | 26 gauge leads for power, ground, CAN and sensor inputs |
| Weight | 6 grams |
| Dimensions | 0.72" x 1.93" (18.3mm x 48.7mm) |
| CAN baud rate | 500K and 1M, jumper configurable |
| Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (jumper configurable) |
Source Code
Power and CAN
Pin 1 is on left when facing board connector
| Pin | Assignment | Notes |
| 1 | 9-15v Power | Connect this to switched ignition power. 0.25A max consumption. |
| 2 | CAN High | |
| 3 | CAN Low | |
| 4 | Ground |
Sensor connections
| 1 | Analog 4 input | 0-5v input |
| 2 | Analog 3 input | 0-5v input |
| 3 | Analog 2 input | 0-5v input |
| 4 | Analog 1 input | 0-5v input |
| 5 | Voltage reference output (for powering sensors) | 5v @ 0.5A |
| 6 | Ground reference |
CAN termination
AnalogX CAN bus API
Adjusting Base ID
Address
| Offset | What | Value |
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Configuration Group 1
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
| 5 | Reserved | |
| 6 | Reserved | |
| 7 | Reserved |
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
| 0 | Channel 1, low byte | |
| 2 | Channel 2, low byte | |
| 4 | Channel 3, low byte | |
| 6 | Channel 4, low byte | |
| 7 | Channel 4, high byte |
