AnalogX2
In the kit you will receive:
- AnalogX2 module
Harness / Cabling
| SKU | Description |
| ASL_DUAL_CAN_HUB | Powered, 8 port dual CAN bus hub kit |
| ASL_M8_CAN_EXT_0.5M ASL_M8_CAN_EXT_1M ASL_M8_CAN_EXT_2M ASL_M8_CAN_EXT_3M ASL_M8_CAN_EXT_4M |
CAN extension cable, M8 4P female to M8 4P male, 0.5 - 4 Meter lengths |
Sensor Connections
| SKU | Description |
| ASL_4X_SENSOR_SPLITTER | 4X sensor expander |
| ASL_M8_SENSOR_EXTENSION_1M ASL_M8_SENSOR_EXTENSION_2M ASL_M8_SENSOR_EXTENSION_3M ASL_M8_SENSOR_EXTENSION_4M |
| ASL_LINEAR_TEMP_M8 | Linear temperature sensor |
| ASL_10_BAR_DELPHI3_M8 | 10 bar (150 PSI) pressure sensor |
| ASL_150_BAR_DELPHI3_M8 | 150 bar (2175 PSI) pressure sensor |
| ASL_M8_SENSOR_PIGTAIL_2M | Single sensor pigtail for custom sensor connection, 2 Meters |
Bare pigtails
For a custom or non-plug and play installation, these bare pigtail cables are available:
| SKU | Description |
| ASL_DEVICE_CAN_PIGTAIL_1M | CAN + power pigtail for connecting device, M8 4P male to bare wires, 1 meter |
| ASL_M8_QUAD_SENSOR_PIGTAIL_2M | M8 8P male to bare wire quad sensor pigtail, 1M, 24AWG |
Compatible Sensors
- Note - RaceCapture's CAN mapping features currently only supports sensors with a linear (straight-line) response. Sensors with a curved response, such as the Extended Range Temperature sensor is based on a thermistor design, and will not work with the built-in direct CAN mapping. We recommend using a temperature sensor with a linear response, such as the Autosport Labs Linear Temperature Sensor, Texense Liquid Temperature Sensor or similar.
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
- 0.5v 0 bar / = 0 PSI
- 4.5v = 10 bar / 150 PSI
Therefore,
- Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
- 0.5v = 0 bar / 0 PSI
- 4.5v = 150 bar / 2175 PSI
Other sensors
Power and CAN
- Connector: M8 4P Male, A coding
| Pin | Connection | Notes |
| 1 | CAN low | |
| 2 | Power | Red, 12-14v / 50mA |
| 3 | CAN high | |
| 4 | Ground | Black |
Sensor connections
| 1 | Analog/Digital 1 | |
| 2 | Analog/Digital 2 | |
| 3 | Analog/Digital 4 | |
| 5 | Ground | |
| 7 | Analog/Digital 3 | |
| 8 | Ground |
- Note: The AnalogX inputs are very high impedance, allowing connection to existing circuits / sensors without affecting the reading of that circuit. As such, no pull-up or pull-down resistors are provided and must be added externally if needed.
DIP switch settings
| Switch | Function | Description |
| 1 | Termination | Set to ON to enable CAN termination |
| 2 | Address offset 1 | Used to select the base CAN address |
| 3 | Address offset 2 | Used to select the base CAN address |
| 4 | CAN Baud Rate | OFF to enable 1M (default), ON to enable 500K |
CAN termination
No CAN data
Basic mapping test
| Feature | Description |
| Analog sensor input voltage range | 0 - 5v |
| CAN baud rate | 1M and 500K, jumper configurable |
| Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (DIP switch configurable) |
| Harness | M8 4P Male for power + ground, M8 8P for sensor connection |
| Weight | 5 oz (approximately) |
| Dimensions | 60 x 60 (approximately) |
| Environmental | IP65, 0-85C |
AnalogX CAN bus API
Adjusting Base ID
- Switching on ADR1 will add 256 to the base ID
- Switching on ADR2 will add 512 to the base ID.
| ADR2 switch | ADR1 switch | Address |
| Off | Off | 0xE4600 (935424) |
| Off | On | 0xE4700 (935680) |
| On | Off | 0xE4800 (935936) |
| On | On | 0xE4900 (936192) |
Address
| Offset | What | Value |
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Configuration Group 1
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
| 5 | Reserved | |
| 6 | Reserved | |
| 7 | Reserved |
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
| 0 | Channel 1, low byte | |
| 2 | Channel 2, low byte | |
| 4 | Channel 3, low byte | |
| 6 | Channel 4, low byte | |
| 7 | Channel 4, high byte |
