RaceCapture on Raspberry Pi
Revision as of 19:51, 12 December 2021 by GTIspirit (talk | contribs) (SSH activation is under 5 Interfacing Options and not Advanced Options on Pi 4 running Buster)
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
RaceCapture currently requires the Raspberry Pi 3: Raspberry Pi 3.
It is not yet compatible with the Pi 4, due to extensive changes in the graphics subsystem. Expect to see Pi 4 support in the 2.0 version of the app.
Display
Enclosure
Installed on Dashboard
Power Supply
Suggested Power Supplies
Powering RaceCapture
Heat sinking
Installing Rasbian OS
We recommend installing the latest Lite distribution - download from the official site and follow the instructions for burning to an SD card.
Updating to latest packages
sudo apt-get update
sudo apt-get dist-upgrade
Raspberry Pi support
The RaceCapture app is compatible with Raspberry Pi 4 and 3.
Enable GPU driver
Enable Fake KMS under advanced boot options:
sudo raspi-config
Go to Advanced Options -> GL Driver -> Select OpenGL desktop driver with fake KMS
  • Be sure to reboot after exiting raspi-config
Installing dependencies
Activate ssh
Ssh is used to store passwords used by the app. Steps to ensure it is running:
sudo raspi-config
Go under Interfacing Options or Advanced Options and start the ssh service.
Next, at the command prompt enter
ssh-add
to create at least one key.
Install package dependencies
sudo apt-get install mesa-utils libgles2 libegl1-mesa libegl-mesa0
Change the default password
> passwd
Enable Hardware rendering
Enter the following line to enable hardware accelerated rendering.
> sudo adduser pi render
  • Notes:
    • Without this setting, UI rendering will be extremely slow.
    • Assumes RaceCapture is launched as pi. If not, replace pi with the user you are logging in as.
    • If you're coming in to fix this after the fact, you'll need to reboot/re-login to take effect.
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture
Enabling on screen keyboard
Edit the ~/.kivy/config.ini and update the keyboard_mode line with:
``` keyboard_mode = multi```
Automatic start upon power up
sudo nano /etc/rc.local
exit 0
Powering up
Connection and usage
Extra Features
Hardwire buttons
    • N : to indicate 'No"
Additional Tips
