Revision as of 20:15, 7 February 2023 by Brentp (talk | contribs) (Created page with "==Install ubuntu 22.x== Install ubuntu 22 in the typical way. * Select Automatic Login without password ==Disable keyring popup== [https://linuxconfig.org/how-to-disable-keyring-popup-on-ubuntu Disable the keyring popup] ==Install dependencies== <pre> sudo apt-get install v4l-utils tk gstreamer1.0-plugins-bad gstreamer1.0-libav </pre> ==Enable access to RaceCapture serial port== <pre> sudo adduser $USER dialout sudo echo "ATTRS{idVendor}==16d0, ATTRS{idProduct}==07f1,...")
Install ubuntu 22.x
  • Select Automatic Login without password
sudo echo "ATTRS{idVendor}==16d0, ATTRS{idProduct}==07f1, MODE=0666" | sudo tee /etc/udev/rules.d/70-autosportlabs.racecapture.rules
Hide Ubuntu Top bar
Hide top bar
Hide side bar
sudo apt install gnome-shell-extensions
Now run extensions tool, set Ubuntu Dock -> OFF
Download the latest RaceCapture app for Linux
http://podium.live/software
Extract the RaceCapture app archive
tar -xzf <downloaded filename>
Launch RaceCapture app
./run_racecapture_linux.sh
Enable fullscreen mode & Default dashboard mode
  • Go to Setup / App Preferences
  • set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
