Setup
Install ubuntu 22.x
- Select Automatic Login without password
Disable keyring popup
Run the installer
do it
Enable fullscreen mode & Default dashboard mode
- Go to Setup / App Preferences
- set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
