Revision as of 18:24, 10 May 2023 by Brentp (talk | contribs) (Cost)
  • Local video recording
Cost
How hard is it to setup?
  • Typing computer commands
  • Plugging in cables
  • Editing configuration files
This ability is within the realm of someone with moderate computer skills. If the instructions seem daunting, find someone to help you along. We will also be offering a pre-packaged setup that take care of most of the setup steps.
Parts you will need
Compatible Systems
  • Any existing RaceCapture system will work.
Micro computer system
The micro computer will receive data from RaceCapture and is responsible for rendering video+data, encoding, and broadcasting the video to youtube or similar streaming platform.
Recommended
Alternatives
A micro system with an Intel I5-6500 through I5-7600 + SSD + 8GB RAM is an acceptable option as well. This may be a system you already have or can get surplus for a minimal cost.
  • Look for these options:
Candidates
12v DC to DC converter
  • Tips:
Recommended
  • KFD 100W universal car charger
  • Notes:
Cameras
Recommended
Alternatives
  • Tips:
Microphone
  • Candidates:
Hotspot/Router
Most any hostspot should work, but for the very best performance and reliability, these options should be considered:
Setup
Connect a keyboard, mouse, and monitor to the rendering/streaming computer and install Ubuntu.
Install ubuntu 22.x
Disable keyring popup
From the desktop, choose log out, and log back in with the password you created during the installation step.
  • Note: Disabling the keyring is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
