- Rich graphics overlay in realtime
- Local video recording
Cost
How hard is it to setup?
- Typing computer commands
- Plugging in cables
- Editing configuration files
System Diagram
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
- Look for these options:
Candidates
12v DC to DC converter
- Tips:
Recommended
- Notes:
Cameras
Alternatives
- Tips:
Microphone
- Candidates:
Hotspot/Router
Setup
Install ubuntu 22.x
- Install Ubuntu with the following options:
- During installation, choose the option to download / install updates, including "non-free" software updates (which includes video drivers)
- Select Automatic Login without password.
Disable keyring popup
- Notes
- This step is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
- set Fullscreen -> ON
- Turn off Session Recording
Dashboard Preferences
- Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture] audio_device=1 [local_recording] video_dir=$HOME/Videos [streaming] streaming_url=rtmp://a.rtmp.youtube.com/live2/<streaming key>
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t then c
Log out
- Press ctrl_t then :
- Type 'quit' and press <enter>
