How To Update Firmware
Firmware upgrade steps
Applies to:
- RaceCapture/Pro MK4, MK3, and MK2
- RaceCapture/Apex
- PodiumConnect MK2 and MK1
- RaceCapture/Track MK3, MK2, and MK1
- How to video: Video: How to update firmware for RaceCapture/Pro
Save your configuration
Download the firmware
- Note Ensure you download the correct firmware for your device (matching the product name), or the firmware process will fail to complete.
Flash the firmware
- Note: Flashing is only possible via the USB interface, so you must use the desktop version of the RaceCapture app.
Steps
Updating Firmware
- Unzip the firmware your downloaded to a location on your computer.
- Connect your system to your Windows or OSX computer using the included USB cable.
- Run the RaceCapture app, and confirm that it is connected.
- Navigate to the Setup view
- Save your current configuration. The firmware upgrade may reset your RaceCapture device to a factory default.
- Press Read to read the current configuration and then press Save to save it to a file.
- Select the Firmware section in the left menu.
- Note: - If the RaceCapture app cannot read the configuration, you may need to first Open a previously saved configuration so you can access the firmware page.
- Press the Update Firmware Button
- Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - and press Open
- The firmware will begin updating - watch for the progress to go 0-100%.
- Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your system.
- Confirm your firmware is updated by viewing the firmware version in the upper right corner of the RaceCapture app, after connecting.
- Press the 'Configuration' button to navigate to the configuration section.
- On the left menu, select Firmware
- On the firmware screen, press the button "Update Firmware"
- Navigate to the firmware file ending in ".ihex"
- Select this file. The firmware will update and show a percentage progress indicator.
- If there is a problem detecting RaceCapture/Pro, unplug/replug and restart the app.
Alternative method
- While holding down the button on RaceCapture/Pro, power it up by plugging in to USB.
- You should observe a rapidly flashing LED on the unit: this means it's in bootloader mode.
- Navigate to Setup.
- Load a previously saved configuration file.
- Navigate to the firmware update view, then follow the process to update firmware.
Issues
If you get an 'Unable to load bootloader' error, try this work around. https://www.youtube.com/watch?v=A-WqZItNB9E
Problems? Post to the forums with the issue you're seeing - we will help you promptly.
RaceCapture/Pro MK1
- Hold down the front panel button on RCP right at the beginning of the process, before running flashRCP.bat
- When asked 'is this your first time flashing' say 'No' so it will re-install the bootloader drivers
- Then proceed with the firmware flash update.
Alternatively:
Mac Users
