RaceCapture-Pro MK4S Sensors
Delphi-Style
This is -40 to 150C Linear temperature sensor with plug and play harness. The specification of the sensor are as follows.
- Connection Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
