RaceCapture-Pro MK4S Sensors
Revision as of 00:14, 3 December 2023 by Abdurrehman Akhtar (talk | contribs) (→Temperature Sensors)
Delphi-Style
- Connection Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
[ Wells SU109 : Engine Coolant Temperature Sensor ]
