RaceCapture-Pro MK4S Sensors
Delphi-Style
- Connection Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
[ Wells SU109 : Engine Coolant Temperature Sensor ]
