RaceCapture-Pro MK4S Sensors
Revision as of 21:28, 3 December 2023 by Abdurrehman Akhtar (talk | contribs) (→Temperature Sensors)
GM-Style
- Thread Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
- Thread Size : 3/8" NPT
- Cable length : N/A
- Body Material : Copper
Delphi-Style
- Voltage supply : 5V
