RaceCapture-Pro MK4S Sensors
GM-Style
  • Thread Size : 1/8″ NPT
  • Cable length : 1 Meter
  • Voltage supply : 3-5V
  • Thread Size : 3/8" NPT
  • Cable length : N/A
  • Body Material : Copper
  • Pigtail :Pico 5616pt
  • Body Material : Brass
Delphi-Style
  • Voltage supply : 5V
Pressure Sensors
Fluid Pressure
  • Cable length : 2 Meter
  • Mfg / Prt : AEM 30-2131-150
  • Mfg / Prt : 12223861 (GM)
  • Output : 0.2 to 4.9 V
  • Use : An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems.
Pulse/Speed/RPM Sensors
  • Mfg / Prt : ASL_COILX
Distance Sensors
Angle/Rotation Sensors
Air / Fuel Ratio Sensors
Wiring Analog Sensors
