ESP32-CAN-X2/RevC
6 pin JST-PH Connector
The ESP32-CAN-X2 REV C development board provides an additional 6-pin connector header at the top of the board to support CAN communication. This header makes wiring the device more convenient and robust. The CAN communication connection pinout details are given in the pinout section below. Top Header Pinout
The header supports CAN communication. Pin count starts at the left viewing the board from the top. The pinout configuration of the header is shown in image given below.
| 4 | GND | Ground |
| 5 | CAN1H/2.7A | high-level signal for the first CAN channel |
