LoRaWAN-bolt-on
Revision as of 17:15, 30 January 2025 by Abdurrehman Akhtar (talk | contribs) (Created page with "=Introduction= The LoRaWAN Bolt-on module integrates the AI Thinker RA-02 LoRa module onto the ESP32-CAN-X development board. It enables long-range wireless communication with low power consumption, making it ideal for IoT applications such as remote sensing, smart agriculture, and industrial automation. File:RA-02 LoRa Module.png =Features= * AI Thinker RA-02 LoRa module based on the SX1278 LoRa transceiver. * Supports LoRaWAN protocol for long-range communication...")
  • AI Thinker RA-02 LoRa module based on the SX1278 LoRa transceiver.
  • Supports LoRaWAN protocol for long-range communication.
  • Frequency: 433MHz (or other regional LoRa frequencies as per regulations).
  • Spread spectrum communication with high noise immunity.
  • Low power consumption and deep sleep support.
  • Data transmission up to 10 km in open environments.
  • SPI interface for communication with the ESP32-CAN-X.
  • Compact SMD package with 16 pins (8 on each side).
  • External antenna support via u.FL (IPEX) connector.
Getting Started
Components
The LoRaWAN Bolt-on includes:
  • AI Thinker RA-02 LoRa Module
  • Custom Printed Circuit Board (PCB)
  • 2 x 20-pin Headers (available separately)
Hardware Connection
The RA-02 module is an SMD package and will be directly soldered onto the PCB.When stacking the LoRaWAN Bolt-on onto the ESP32-CAN-X development board, ensure proper alignment of the icons on the boards, particularly the LoRa antenna and USB positions, to maintain correct functionality.
Separate Headers
Additionally, 2 x 20-pin headers must be soldered onto the PCB to provide the necessary connections. These headers are available from various sources such as Amazon and eBay (male/female versions available).
Block Diagram, Pin Description, and Connections
Block Diagram
Pin Description
Pin No. Name Description
1 GND System Ground
2 GND System Ground
3 3.3V Power Supply (3.3V)
4 RESET Reset Pin
5 DIO0 Digital I/O for LoRa Interrupts
6 DIO1 Digital I/O for LoRa Interrupts
7 DIO2 Digital I/O for LoRa Interrupts
8 DIO3 Digital I/O for LoRa Interrupts
9 GND System Ground
10 DIO4 Digital I/O for LoRa Interrupts
11 DIO5 Digital I/O for LoRa Interrupts
12 SCK SPI Clock
13 MISO SPI MISO (Master In Slave Out)
14 MOSI SPI MOSI (Master Out Slave In)
15 NSS SPI Chip Select
16 GND System Ground
ESP32-CAN-X Connections
Connections RA-02 Pin ESP32 GPIO
MISO Pin 13 GPIO16
MOSI Pin 14 GPIO15
SCK Pin 12 GPIO17
NSS Pin 15 GPIO18
RESET Pin 4 GPIO05
DIO0 Pin 10 GPIO04
GND Pin 1/2/9/16 GND
3.3V Pin 3 3.3V
3.3V Pin 3 3.3V
RX LED NC GPIO09
TX LED NC GPIO08
Demo Code
Access the source code repository through the provided link.
