RaceCaptureTrack MK4
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
- Mount the unit in a concealed, protected area of the vehicle, away from direct heat sources and moisture.
- Use hook-and-loop (Velcro) fasteners or other suitable mounting methods to secure the unit in place while allowing for easy removal if needed.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
- M8 6-Pin Female Connector (CAN1 / CAN2 / Power)
- M8 4-Pin Female Connector (CAN1 / Power)
- RP-SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
- Mount the antenna on the roof of the vehicle using the supplied magnetic base.
- Maintain a minimum separation of 3 feet (1 meter) from other transmitting antennas (e.g., cellular, FM/AM radio) to reduce signal interference.
- You can also place it on the dashboard, with an unobstructed view of the sky or on the rear parcel shelf, under the back window.
Powering up the Module
The RaceCapture/Track MK4 can be powered using the following methods: USB Power (USB Type-C) You may power the device via the USB Type-C port using any of the following sources:
- A computer USB port
- A USB car charger
- A USB battery pack
