MJLJ V4 kit assembly guide
Revision as of 17:44, 6 March 2009 by Brentp (talk | contribs) (→‎Components: updated R9 marking code)
Precautions
Surface mount Components
Before you Begin
Familiarize
Do not lose parts
Lighting
Note part orientation
Do not overheat
Assembling the kit
Tools you will need
Parts Inventory
Core Parts
Part Type Value Photo
X2 Connector Molex Right angle, 16 position Molex minifit 16 right angle pcb.jpg
TPS Option
MAP Sensor Option
Surface Mount Parts
Power supply Circuit
Prepare solder pads
Components
  • D4: 12V Zener diode. Note stripe orientation: The silk-screened stripe on the PC board matches the diode's stripe.
If you have difficulty identifying them, increase the lighting- bright light is essential.
  • R9: 680 ohm resistor (marked 681)
Testing Voltages
  • Power supply components:
Apply power to the Molex pads shown in the image using a low current, 9 - 12v power supply source. A 9V battery is ideal for testing.
Verify +5v at the test point. if the test point is covered with green solder mask, you can test on the adjacent pads on D1 or R9. Mjlj v4 power supply vcheck.jpg
  • U1: Verify +5v across the Vdd, Vss pins of U1
  • IC1: Verify approximately +V-Supply (about .6 volts lower than +V-Supply) across the IC1 CD+ and Gnd pins
  • U2: Verify +5v across Vcc and GND pins of U2
  • QG1: Verify +5v across Vcc and GND of oscillator QG1
  • PS1: If optioned for MAP, Verify +5v across PWR and GND pins of the MPX4250a
Main Circuit
Prepare Solder Pads
Components
  • D6,D7: Schottky diode (strip of two diodes, SOD-123 package SOD-123.jpg Note Polarity: Stripe on diode package towards bottom edge of board.
Core Components Installed
Detail on D6,D7 polarity
MAP sensor option
  • C9,C8: 0.1uF capacitor (strip of 2 capacitors, ORANGE stripe on tape)
TPS option
  • D5: Schottky Diode (strip of one diode, SOD-123 package SOD-123.jpg) Note polarity: stripe on diode package oriented towards bottom of board.
  • C14: 15uF capacitor (grey tantalum package) Note polarity Match stripe on component with stripe on board.
  • L1: 1uH inductor (strip of one inductor, 1210 package: 1210 smt inductor.jpg)
Testing Voltages
Before continuing, repeat the voltage testing steps outlined in the power supply build section.
Through Hole Parts
IMPORTANT: It is extremely important you install the through-hole components with the correct orientation! De-soldering a backwards-installed component is extremely difficult and will likely damage the board.
GET IT RIGHT THE FIRST TIME!
Install Components
You may need to re-heat the pad while squeezing the part against the board. Once you are
If not perfect, re-heat solder near the affected corner and correct the connector's position.
MAP Sensor Option
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Installing ICs
  • U1: Install MJLJ V4 Processor Freescale MC908QB8. Note notch orientation
  • IC1: Install ULN2003 transistor array Note notch orientation
Complete board assembly, TPS version
Final Inspection
Solder joints
Part placement
  • Ensure all through hole components are flush.
  • Re-check part orientations: polarity on electrolytic and tantalum capacitor, orientation on diodes, and orientation on ICs and oscillator.
Additional Options
Hard Rev Limiter Module
Enclosure installation
Testing
Verification on the bench
Next Steps
