MJLJ V4 vehicle installation guide
System Overview
Parts you will need
- EDIS module: Acquire an EDIS Ignition module matching your engine type- EDIS-4 for 4 cylinder engines; EDIS-8 for 8 cylinders; EDIS-6 for 6 cylinders
| Type | Donor Vehicle | Years | Market |
| EDIS-4 | Ford Escort | 1990-99 | US |
| Ford Fiesta | 1990-99 | Europe | |
| Mazda 121 | 1996-2001 | Europe | |
| Ford Escort | 1990-2000 | Europe | |
| Ford Sierra | 1990-93 | Europe | |
| EDIS-6 | Ford Ranger Pickup truck | 1990-97 | US |
| Mazda B-Series Pickup | 1990-97 | US | |
| Ford Explorer | 1990-97 | US | |
| Mazda Navajo | 1990-97 | US | |
| Ford Aerostar | 1990-97 | US | |
| Ford Scorpio 2.9 Cosworth | 1996-97(?) | Europe | |
| Ford Mondeo V6 | 1993-1996(?) | Europe | |
| EDIS-8 | Crown Victoria | 1990-97 | US |
| Mercury Grand Marquis | 1990-97 | US | |
| Lincoln Town Car | 1990-97 | US | |
| Ford Thunderbird | 1990-97 | US | |
| Mercury Cougar | 1990-97 | US | |
| Ford Mustang 5.0 | 1990-97 | US |
- Coil packs: Many use the matching Ford coil packs, but typically most OEM coil packs that closely matches the ford EDIS primary(about 0.5 ohms) and secondary(11-13K ohms) DC coil resistance should work fine. Source from donor vehicle, or can be purchased new for a reasonable cost.
- Crank Sensor: We suggest you use a Ford OEM crank sensor- also known as a 'VR (Variable Reluctance) Sensor'- this guarantees best compatibility with the Ford EDIS module. Typically sourced from donor vehicle, or may be purchased new from an auto parts retailer at a low cost (about $20 USD)
- Trigger wheel: The Ford EDIS module requires a 36 tooth wheel with one missing tooth- commonly referred to as a 36-1 wheel. Many adapt the trigger wheel removed from the crank pulley of the donor engine. For example, the Ford Escort 1.9L motor has a crank pulley with a pressed-on ring-shaped trigger wheel when removed, yields a convenient part that can be adapted to the receiving engine. Others machine the pattern directly into the existing crank pulley, fabricate a custom wheel, or purchase a wheel ready made for their engine.
- Component Suppliers
| Location | Company |
| USA | Boost Engineering |
| UK | Trigger Wheels |
EDIS installation
| Type | "N" Degrees BTDC | "N" Teeth |
| EDIS-4 | 90 | 9 |
| EDIS-6 | 60 | 6 |
| EDIS-8 | 50 | 5 |
- Mount the sensor in any convenient way that simplifies bracket design and accommodates mounting points on the engine block.
- Turn the crankshaft to precise Top Dead Center (TDC) for cylinder #1.
- Position the timing wheel onto the crank pulley with the missing tooth aligned to the sensor.
- Now offset the the timing wheel position:
- If your engine turns clockwise when facing the crank pulley, rotate the timing wheel clockwise "N" Teeth.
- If your engine turns counter-clockwise when facing the crank pulley, rotate the timing wheel counter-clockwise "N" Teeth.
- mark this final location of the sensor wheel onto the crank pulley- then weld or bolt timing wheel into place as appropriate.
Megajolt Lite Jr. Wiring
- Use 16 gauge wire for the MJLJ ground connection. 18-20 gauge wiring is fine for signal connections.
- If the MJLJ is fitted with the internal hard rev limiter, it's recommended you use at least 16 gauge wire for +12v power and the Coil Power output, and connect it to a fused circuit with suitable current capacity. Otherwise you may use 18-20 gauge wire for the power connection.
- For MAP based installations ignore the TPS Input.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
Enabling Option Switch
Rev Limit control
Hard Rev Limit
Soft Rev Limit
Auxiliary Input
Analog input source
Hardware Modification
MJLJ Operation
Verification Steps
Verifying MJLJ operation
Verifying Power
Verifying Signals
| What | Where to measure | Expected Voltage | Symptoms | Cause/Resolution |
| VR Sensor | * Measure across VR Sensor terminal * Measure across EDIS pins 5 and 6 |
* 0 volts when not running; * Approx. 2.5V AC when cranking |
No Spark | EDIS must receive signal from sensor for proper operation. Check gap between sensor and trigger wheel (Max 1 mm); No reading when measuring from sensor may indicate defective sensor; Special Note: Sensor is polarized; reverse connections to sensor if a signal is measured but no spark occurs. |
| PIP Signal | * Measure between EDIS pin 1 and ground * Measure at PIP input on MJLJ and ground |
* Approx. 12V when engine not running; * Approx. 5.5V with engine cranking/running |
No RPM reading on configuration software / No control of Ignition Advance; engine running in "limp home mode" | PIP Signal from EDIS must reach MJLJ in order to measure RPM and command Ignition Advance via SAW pulse. Check wiring between EDIS and MJLJ; ensure appropriate pins are wired. |
| SAW Signal | * Measure between EDIS pin 3 and ground * Measure at SAW output on MJLJ and ground |
* 0V when engine not running; * Less than 0.2V AC when cranking |
RPM Reading in configuration software, but no control of Ignition Advance; engine running in "limp home mode" | SAW Pulse emitted from MJLJ must reach EDIS module in order to command desired Ignition Advance at run-time. Check wiring between MJLJ and EDIS; ensure appropriate pins are wired. |
| TACH output | Measure at TACH_OUT output on MJLJ and ground | * Approx. 5.5V when engine cranking/running | Tachometer does not see TACH_OUT signal; external electronics not reacting to TACH_OUT signal | MJLJ outputs a pulse on TACH_OUT when PIP pulses are received. Ensure MJLJ is powered and properly receiving PIP pulse. |
