Hard rev limiter 1.2.0
General Information
Theory of Operation
Schematics
Board
Assembling the kit
Tools you will need
- A fine-tipped, low wattage soldering iron is necessary for precision work.
- Probably the best tool - a cross-action set of tweezers. This tool is normally closed, allowing you to hold parts with a relaxed grip and reduced tremors.
- Solder wick. Too much solder and you'll create ugly blobs and solder spikes. use this to clean up your joints by drawing away excess solder.
- A magnifying glass, preferably illuminated, is useful for identifying package markings and inspecting solder joints.
Parts Inventory
Part Number | Description |
U1 | FDS6681Z P-Channel Mosfet |
R1-R10 | 180 ohm, 1W SMT 2412 |
Q1 | SMBT2907A PNP transistor |
R11 | 10K 1206 SMT |
R12 | 100K 1206 SMT |
Surface mount soldering
Soldering lead-less surface mount components usually involves tacking one lead down to the board to fix it in place and then working on the remaining leads. With the smaller components, be careful to not apply excessive heat- just enough is needed to flow the solder into the joint. Excessive heat, at minimum, will cause small parts to slide off the pads, and at worst, can destroy them.
Installing the parts
Preparing the solder pads
Installing the power resistors
Installing supporting components
Install Q1. For kit builders, a 2N3906 PNP transistor has been supplied for ease of assembly. Insert Q1 with the orientation shown, leaving enough lead length to fold the transistor flat against the board- this will be needed to ensure low profile installations.
Installing power transistor
Final Inspection
Installing the Hard Rev Limiter
Physical Installation
It's up to the user to determine how to install the rev limiter module. Following are a couple of possible installation options.
Since the resistor array generates heat when rev-limiting is active, ambient temperature and air flow across the module will affect the duty-cycle of the unit- meaning how often and long you'll be able to be 'on' the rev-limiter.
Freestanding installation
Integrating into the MJLJ enclosure
The Rev Limiter board is sized to fit both the V3 and V4 controller. Rotate the controller to fit the enclosure rails.
V4 Controller
Wire the Rev Limiter board to the +12V, Coil Power, Trigger and ground pads on the V4 board. Use 14 gauge wire for the +12V and Coil Power pads and 22-18 gauge wire for trigger and ground.
Refer to the following for wiring and board installation:
V3 Controller
Slide the board into one of the slots above the main board.
External Wiring Diagram
With this approach, several wiring possibilities exist:
- Cut a hole in the end plate, and route all wires outside the case, looping back to the MJLJ wiring harness plug;
- Cut a hole in the end plate, externally expose the +12v and coil pack connectors, but connect the ground and trigger with jumpers to the inside of the case.
- Most ambitious: wire everything internally:
- Jumper GND connection to MJLJ GND;
- Jumper +12V connection to MJLJ +12V (14 gauge wire);
- Use a thicker gauge wire (14 gauge) for MJLJ +12V power, if necessary, as the +12v supply will supply current to the coil in addition to powering the MJLJ electronics;
- Jumper trigger input to REV_LIMIT output on MJLJ board;
- Cut the REV_LIMIT trace on the MJLJ board running from the ULN2003 to the REV_LIMIT connector pin. The REV_LIMIT pin will now be the new COIL power supply..
- Connect the Rev limit COIL output to REV_LIMIT pin on MJLJ connector.
