TachAdapter
Revision as of 06:29, 24 August 2011 by Brentp (talk | contribs) (Created page with "==Tachometer Adapter== This small board adapts a Tachometer to up to 4 individual coil packs, making it capable of handling 4, 6 or 8 cylinder wasted spark applications. [[Imag...")
Tachometer Adapter
Installation is straightforward: - Connect Coil 1,2,3 and 4 to the drive signals to each coil packs as necessary. - Connect the tach output to the input of your tachometer. - Wrap the board with electrical tape or shrink tubing- the board is small enough to integrate into your wire harness / bundle.
Example Wiring
Example wiring for a 4 cylinder wasted spark application: Yellow wire connects to Tachometer input; red and black wire connect to the drive signals for the coil packs.
