RaceCapturePro installation guide
Revision as of 03:44, 28 September 2012 by Brentp (talk | contribs) (RaceCapture installation guide work in progress)
Terminal Block Connections
Connections Faceing Terminal Block, from left to right
  • Ground/Common
  • +12v
  • Analog/Frequency out 4
  • Analog/Frequency out 3
  • Analog/Frequency out 2
  • Analog/Frequency out 1
  • +5V Voltage reference
  • Analog input 7
  • Analog input 6
  • Analog input 5
  • Analog input 4
  • Analog input 3
  • Analog input 2
  • Analog input 1
  • General purpose input/output 3
  • General purpose input/output 2
  • General purpose input/output 1
  • Frequency/pulse input 3
  • Frequency/pulse input 2
  • Frequency/pulse input 1
Expansion Port
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • LED1
  • LED2
Indicates
Pushbutton
Communication Ports
  • Port 1
  • Port 2
used for GPS module
