RaceCapturePro Sensors
Revision as of 03:31, 5 January 2013 by Brentp (talk | contribs) (→Sensors: added graphics / formatting)
Engine Temperature
GM Coolant sensor
A popular sensor with custom engine management systems.
  • Part numbers
Wells SU109 : Standard Motors Products (SMP) TX3
  • Pigtail
Pico 5615pt
  • Format
This sensor has a 3/8" NPT threaded brass body and a 2 pin terminal.
  • Analog Channel configuration
<Race Capture Pro analog channel configuration data>
  • Notes
Can be used for air inlet temperature for normally aspirated engines
Air Inlet Temperature
GM Sensor
A sensor made popular with custom engine management systems.
  • Part numbers
Wells SU107 : Standard Motors Products (SMP) AX1
  • Pigtail
Pico 5616pt
  • Analog Channel Configuration
  • Notes
Use for measuring air inlet temperature. Exposed sensing element, necessary for boosted engines where fast response times are necessary. Due to the fragility of the sensing bulb, it is necessary to pot the base of the sensor leads with sensor-safe silicone when used in high vibration environments.
Oil Temperature
Ambient Air Temperature
Pressure Sensors
Fluid Pressure
Boost / Vacuum
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position
Linear Sensors
