RaceCapturePro Sensors
Revision as of 03:44, 5 January 2013 by Brentp (talk | contribs) (changed to table)
Engine Temperature
GM
  • Pigtail Pico 5615pt
GM
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Pressure Sensors
Fluid Pressure
Boost / Vacuum
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position
Linear Sensors
