RaceCapturePro Sensors
Engine Temperature
GM
  • Pigtail Pico 5615pt
GM
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Quattro Brake Fluid pressure sensorFile:Http://s3.amazonaws.com/fcp-product-photography-us/public/assets/products/77553/product/open-uri20120713-31620-geo69a.?1342170655 http://s3.amazonaws.com/fcp-product-photography-us/public/assets/products/77553/product/open-uri20120713-31620-geo69a.?1342170655 $31.55
XT racing fluid pressure sensor http://fs7.motosport.com/is/image/Motosport/XT-S01-_is?$NewPDP2$ $109.99
Boost / Vacuum
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Sensor Breakout Board
SensorX
