RaceCapturePro installation guide
Terminal block connections
Connections Faceing Terminal Block, from left to right
- Ground
- +12v
- Analog/Frequency out 4
- Analog/Frequency out 3
- Analog/Frequency out 2
- Analog/Frequency out 1
- +5V Voltage reference
- Analog input 7
- Analog input 6
- Analog input 5
- Analog input 4
- Analog input 3
- Analog input 2
- Analog input 1
- Frequency/pulse input 3
- Frequency/pulse input 2
- Frequency/pulse input 1
Power Connection
Analog Inputs 1-7
- Active Sensors/Signals
- Resistive sensor
When connecting resistive style sensors, like many temperature and pressure sensors, one terminal of the sensor is connected to ground, and the other is connected to the Analog input, with a pullup resistor connected to the +5V Voltage Reference on the terminal block. A 2.2K resistor is recommended for most applications. Our Sensor Breakout Board provides a convenient way to wire up 7 sensors to the RaceCapture/Pro.
Analog/Frequency Outputs 1-4
Frequency/Pulse Input 1-3
These input channels can be used to time the duration between digital pulses for purposes of measuring RPM, shaft speed, and so on. The input accepts 0-5V (protected up to 45V). Each input has a built-in 10K pullup resistor connected to 5V.
Expansion Port
SD Card Slot
USB Port
The USB port
LED Indicators
- Power LED
- LED1
- LED2
- LED3
Pushbutton
Communication Ports
- Port 1
- Port 2
used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
JTAG header
