Engine Temperature
| Mfg
Pic
Pigtail
Part Numbers
Mechanical
Analog Configuration
Notes
| GM
- Wells SU109 : Standard Motors Products (SMP) TX3
- Pigtail Pico 5615pt
3/8" NPT threaded brass body and a 2 pin terminal.
<link to Race Capture analog channel configuration>
Can be used for air inlet temperature for normally aspirated engines
| GM
- Wells SU107 : Standard Motors Products (SMP) AX1
- Pigtail Pico 5616pt
Use for measuring air inlet temperature. Exposed sensing element, necessary for boosted engines where fast response times are necessary. Due to the fragility of the sensing bulb, it is necessary to pot the base of the sensor leads with sensor-safe silicone when used in high vibration environments.
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
| Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
| TI
Needs dev board to connect to inputs.
Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT
*Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor
<link to Race Capture digital channel configuration>
Can be used for 3 position tire temperature, when mounted within 3" of tire
| Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
| GM
3.3 bar MAP sensor
- Sensor: 9373269
- Pigtail: 88987997
fastens with clips
3.3 bar map sensor found on turbo GM products
| DIY
Freescale MPX4250AP 2.5 bar MAP sensor
N/A
custom
custom
<link>
An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems. Can build up a simple circuit on perfboard and be powered by 5V v-ref from Race Capture
Distance Sensors
Suspension Travel
| Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
| DIY
Sharp GP2D12 optical distance sensor
3-pin connector
GP2D12
custom
<link>
Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense
Angle Sensors
Steering Angle
| Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
| DIY
3-pin connector
GP2D12
custom
<link>
Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense. Create a target latched to the steering rod and use the travel out and back of the steering rack rod to denote the travel left and right for steering. This measures true steering(and ignores the speed sensitivity of steering systems, showing actual tire angle result, not steering wheel rotation). It also provides a quick way to verify alignment issues as location vs. gps/accelerometer travel in the "Straight ahead" direction will be at varying angles when alignment issues are present.
Throttle Position
Brake Position/Pressure
Linear Sensors
Sensor Breakout Board
SensorX
