RaceCapturePro Sensors
Engine Temperature
  • Pigtail Pico 5615pt
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
TI Infrared Temperature Sensor samples 3 positions on tire carcass Wcsp6.jpg Needs dev board to connect to inputs. Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor <link to Race Capture digital channel configuration> Can be used for 3 position tire temperature, when mounted within 3" of tire link
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
  • Sensor: 9373269
  • Pigtail: 88987997
DIY Freescale MPX4250AP 2.5 bar MAP sensor MPX4250ap.png N/A custom custom <link> An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems. Can build up a simple circuit on perfboard and be powered by 5V v-ref from Race Capture
Distance Sensors
Suspension Travel
DIY Sharp GP2D12 optical distance sensor Sensor GP2D12.jpg 3-pin connector GP2D12 custom <link> Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense
Angle Sensors
Steering Angle
DIY Sharp GP2D12 optical distance sensor Sensor GP2D12.jpg 3-pin connector GP2D12 custom <link> Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense. Create a target latched to the steering rod and use the travel out and back of the steering rack rod to denote the travel left and right for steering. This measures true steering(and ignores the speed sensitivity of steering systems, showing actual tire angle result, not steering wheel rotation). It also provides a quick way to verify alignment issues as location vs. gps/accelerometer travel in the "Straight ahead" direction will be at varying angles when alignment issues are present.
Throttle Position
ASL Ford type throttle position sensor TPS-45.jpg see pigtail below Standard Motors SMP TH45 equivalent custom Existing style Throttle position sensor available from AutoSport Labs link
ASL Ford type throttle position sensor 5752pt.jpg 3-pin connector fits SMP TH45 above custom Existing style Throttle position sensor available from AutoSport Labs link
Brake Position/Pressure
ATE Brake Fluid Pressure sensor Brakepressuresensor.jpg solder on tabs (2 wire) If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. <link to Race Capture analog channel configuration> threads into T fitting on brake line. Use professional brake fitting tools! link
Linear Sensors
Sensor Breakout Board
We've created an optional sensor breakout / distribution board that will make it easier to use sensors that require pullup resistors as well as making available multiple ground and 5V Vref connections. The built-in pullup resistors are easily disabled by breaking a designated trace on the board. This board is compact; enough to be bundled inline with your wiring harness. SensorX board.png
SensorX
