RaceCapturePro Sensors
Engine Temperature
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
Mfg | Description | Pic | Pigtail | Part Numbers | Mechanical | Analog Configuration | Notes |
TI | Infrared Temperature Sensor samples 3 positions on tire carcass | Needs dev board to connect to inputs. | Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT | *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor | <link to Race Capture digital channel configuration> | Can be used for 3 position tire temperature, when mounted within 3" of tire link |
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
ASL | Ford type throttle position sensor | see pigtail below | Standard Motors SMP TH45 equivalent | custom | Existing style Throttle position sensor available from AutoSport Labs link | ||
ASL | Ford type throttle position sensor | 3-pin connector | fits SMP TH45 above | custom | Existing style Throttle position sensor available from AutoSport Labs link |
Brake Position/Pressure
ATE | Brake Fluid Pressure sensor | solder on tabs (2 wire) | If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. | <link to Race Capture analog channel configuration> | threads into T fitting on brake line. Use professional brake fitting tools! link | ||
DIY | Freescale MPX4250AP 2.5 bar MAP sensor | on part | ATV type sensor | threads into T fitting on brake line. Use professional brake fitting tools! | avail at 150psi, or 2000psi, needs 12v supply link |
Linear Sensors
Sensor Breakout Board
Hardware Expansion board <coming soon> look for it to fit into the RJ-45 jack in the back of the RaceCapture Pro.
