Engine Temperature
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Analog Configuration
Notes
GM
- Wells SU109 : Standard Motors Products (SMP) TX3
- Pigtail Pico 5615pt
3/8" NPT threaded brass body and a 2 pin terminal.
<link to Race Capture analog channel configuration>
Can be used for air inlet temperature for normally aspirated engines
GM
- Wells SU107 : Standard Motors Products (SMP) AX1
- Pigtail Pico 5616pt
Use for measuring air inlet temperature. Exposed sensing element, necessary for boosted engines where fast response times are necessary. Due to the fragility of the sensing bulb, it is necessary to pot the base of the sensor leads with sensor-safe silicone when used in high vibration environments.
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
TI
Infrared Temperature Sensor samples 3 positions on tire carcass
Needs dev board to connect to inputs.
Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT
*Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor
<link to Race Capture digital channel configuration>
Can be used for 3 position tire temperature, when mounted within 3" of tire link
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Tire Pressure
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
VDO
REDI-Sensor™ Multi-Application TPMS Sensors
self powered wireless
OEM style
custom
Wireless tire pressure monitoring system link
ASL
Ford type throttle position sensor
turnkey unit
custom self powered wireless
Wireless tire pressure monitoring system includes wireless receiver and gauge link
Boost / Vacuum
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
GM
3.3 bar MAP sensor
- Sensor: 9373269
- Pigtail: 88987997
fastens with clips
3.3 bar map sensor found on turbo GM products
DIY
Freescale MPX4250AP 2.5 bar MAP sensor
N/A
custom
custom
<link>
An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems. Can build up a simple circuit on perfboard and be powered by 5V v-ref from Race Capture
Distance Sensors
Suspension Travel
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
Vishay Semiconductors
Specialized Optical Switch
3-pin connector
Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000
Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out
<link>
Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link
Angle Sensors
Steering Angle
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
DIY
Sharp GP2D12 optical distance sensor
3-pin connector
GP2D12
custom
<link>
Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense. Create a target latched to the steering rod and use the travel out and back of the steering rack rod to denote the travel left and right for steering. This measures true steering(and ignores the speed sensitivity of steering systems, showing actual tire angle result, not steering wheel rotation). It also provides a quick way to verify alignment issues as location vs. gps/accelerometer travel in the "Straight ahead" direction will be at varying angles when alignment issues are present.
Throttle Position
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
ASL
see pigtail below
Standard Motors SMP TH45 equivalent
custom
Existing style Throttle position sensor available from AutoSport Labs link
ASL
3-pin connector
fits SMP TH45 above
custom
Brake Position/Pressure
Mfg
Pic
Pigtail
Part Numbers
Mechanical
Notes
ATE
Brake Fluid Pressure sensor
solder on tabs (2 wire)
If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237.
threads into T fitting on brake line. Use professional brake fitting tools! link
DIY
on part
ATV type sensor
avail at 150psi, or 2000psi, needs 12v supply link
Linear Sensors
Sensor Breakout Board
SensorX
