RaceCapturePro installation guide
Revision as of 19:07, 21 April 2013 by Brentp (talk | contribs) (→‎Frequency/Pulse Input 1-3: added note about old tach signal wiring.)
Terminal block connections
Connections facing terminal block, from left to right. 20 gauge wire works well for the connections.
  1. Ground
  2. +12v
  3. Analog/Frequency out 4
  4. Analog/Frequency out 3
  5. Analog/Frequency out 2
  6. Analog/Frequency out 1
  7. +5V Voltage reference
  8. Analog input 7
  9. Analog input 6
  10. Analog input 5
  11. Analog input 4
  12. Analog input 3
  13. Analog input 2
  14. Analog input 1
  15. General purpose input/output 3
  16. General purpose input/output 2
  17. General purpose input/output 1
  18. Frequency/pulse input 3
  19. Frequency/pulse input 2
  20. Frequency/pulse input 1
Power Connection
Analog Inputs 1-7
  • Active Sensors/Signals
  • Resistive sensor
Analog/Frequency Outputs 1-4
TACH SIGNAL NOTES
Interfacing directly to the signal of the coil pack primary will require an opto-isolated interface board such as the design here, currently under testing. Other interface boards can be used, provided they provide a clean square wave signal to RaceCapture/Pro.
Expansion Port
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Pushbutton
Communication Ports
  • Port 1
  • Port 2
Used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
JTAG header
